Carburator
Newguy
02-17-2002 00:03:11
On my TEA20, the fuel line is attached to the front of the carburator (the Zenith type). I have never seen this before on any other tea. The tractor has had problems running lately, could this be the problem? Any help would be appreciated. Thanks!
Jone
02-17-2002 16:16:31
 Re: Carburator in reply to Newguy, 02-17-2002 00:03:11
Are the fuel line attached to the front, as towards the front tires, or towards the wall in your garage???
It is possible to run the fuel line in thru both openings on top of the carb...mine has it in thru the front as mentiond above, and that is the normal setting...
There were different Zenith Carbs, the 24T-2 Standard, and the 24T-2 Min/Max
the main valve/spreader has a pin on the 24T-2 standard carb, and the 24T-2 Min/Max, has a wheel with a small knob on it, thats how to see the difference, on the Standard type, the valve should be 2 turns open (against the clock), and the Min/Max 1 turn open (against the clock)This was the problem on my TEA (I had the MIN/MAX type, but the main valve/spreader on the carb had been changed in the shop, when i got it rebuilt. The Min/Max type has a tiny hole thru the center of the main valve/spreader, and the Standard is just an ordinary needle)
Regards Jone Tveitane
And please reply if im incorreck, or somthing aint clear enough....
