Oil leak from front of transmission on Tea20
Barry
02-20-2002 04:02:50
Oil is coming out the bottom of the bellhousing. I assume this is caused by a worn out seal on the tranny front shaft. It seems to drop oil mainly when using the hydraulic lift (letting it down I think) Are there any problems I may run in to when replacing the seal? Other than keeping both ends of the Fergy off the ground while I do it that is!!
Bernie
02-21-2002 07:35:23
 Re: Oil leak from front of transmission on Tea20 in reply to Barry, 02-20-2002 04:02:50
Just 2 short weeks ago I split my tea20 to change the rear main oil seal (black oil vs. gear lube comming out of lower trani drain hole). Also had to change trani input seal as gear lube was also coming out rear lower drain hole. Trani input seal is very easy to change. Local Massey dealer had engine seal and trani seal, I bought 2 of each... (Just in case if you know what I mean). If you have to change both seals you'll need to buy a lower end gasket set for the engine also. One thing that you'll need to inspect is the expansion plugs that seal the shifter rail bosses. They're located on the inner forward face of the trani housing at the top. If these plugs are loose or missing then gear oil WILL LEAK! With all of the parts assembled it only took me 8 hours to split the tractor change the parts (clutch included, oil soaked). If you do both do the engine first as you can then use the trani input shaft to align the clutch assembly. Have fun... e-mail me if you want any tips!
Pete Tatham
02-21-2002 00:34:03
Barry, The rear crankshaft oil seal could also be the culprit. Either way, you'll have to split the tractor to find out. When you get into it it would be advisable to renew both while youre in there. Its not a complex procedure, well within the capability of Mr average mechanic. Buy a manual and just follow the steps through.
If you need any extra advice I'm sure you'd get lots of replies to a posting on this board.
