Buying a ferguson TEA20
Nick
02-21-2002 10:36:14
I'm going to look at a TEA20 (petrol) soon. I one for light work on my smallholding and I've always had a soft spot for Fergusons. I've never own a tractor before but I am mechanically competant. What should I look out for? Any advice would be gratefully received. I live in the UK but help from anywhere is welcome!
Thanks in advance.
Phil (VA)
02-22-2002 11:25:33
 Re: buying a ferguson TEA20 in reply to Nick, 02-21-2002 10:36:14
Well, of course check the engine for smoking and good compression. Aside from that, the big ticket items might be rear tires, hydraulics (check with implement attached), steering, and clutch and transmission. Clutches are not expensive, but the labor is semi-expensive, unless you do it. Minor items include rear brakes (and axle oil seals), gages, fuel tank leaks, seat assembly. Of course badly rusted sheet metal is obvious. Hope that helps.
