Undermount mower for TO-20
Neal
10-26-1999 11:45:39
My question is, has anyone seen an undermount mower used on a TO-20. If so what brand. The following is the long version of what I have found so far. Woods does not make a mount kit for this tractor. Haven't found anyone else yet either. I e-mailed Woods and their response was to use a universal mount kit and that I had to put 12.4x 28 tires on the back as a minimum and preferably go to 32" rims. I will need turf tires anyway so that may not be to bad. Next thing to do is find an 8N with a Woods mower and see how it mounts because I have never had good luck with any universal or one size fits all product. I also don't understand why clearance is a problem for the TO and not the 8N.In the end I may go with a 3pt but I would prefer the undermount.
Neal
Chuck (CA)
10-27-1999 05:49:23
 Re: Undermount mower for TO-20 in reply to Neal, 10-26-1999 11:45:39
Neal,
There was discussion on the N board a while back about the belly mower vs the 3 point. What seemed to come out of it, is even though the belly mower is neat and easy to manuver, it is a pain to install and uninstall. In fact, you're almost better off having a tractor dedicated to a belly mower and have another tractor for your other chores.
You might want to check the archives for it. I seemed to recall a picture of some fella's absolutely gorgeous N with the setup you're looking for.
Chuck
Neal
10-27-1999 09:55:08
 Re: Re: Undermount mower for TO-20 in reply to Chuck (CA), 10-27-1999 05:49:23
Thanks Chuck.
I suspect you are right and thats what I had in mind. About half of what I mow now is my front lawn and in the spring (actually most of the season) AG tires will tear up the lawn so I really have to go with turf tires. I'm told that they have almost no traction for other work so I would have to keep swapping tires. I think you will find that the 8N mower you saw can be found at the URL attached.
Neal
