Battery polarity
NCtim
02-27-2002 13:12:31
How can I test for battery polarity. I have a converted TEA-20. Before I put the alternator on I was using this as a positive ground 12 volt, no charging at all. When the battery went low I just charged it up again.
I'm having some ignition trouble and I'm wondering if this may be the problem because now I'm using the same battery in a negative ground configuration with an alternator.
Any help is appreciated.
NCtim
RWK in WI
03-01-2002 06:10:03
 Re: battery polarity in reply to NCtim, 02-27-2002 13:12:31
If you reversed the polarity of the tractor, you then need to reverse the polarity of the coil.
Reverse the two leads to the coil. I keeps the spark at the spark plug going in the direction that fires best.
Good luck.
