FERG MODEL 20 WITH NO GENERATOR
FRED MABEY
02-27-2002 15:17:51
THE 1950 MODEL 20 TRACTOR I GOT HAS NO GENERATOR OR BRACKET SOMEBODY TOOK IT OFF TO GET A CONVERSION DONE AND LOST ALL OF THE PARTS. I FOUND A CONVERSION KIT FOR A MODEL 30 AND NEED TO KNOW IF IT WILL FIT MY TRACTOR. IF NOT WHAT CAN I DO TO GET MY TRACTOR WORKING.
Duner Wi
02-28-2002 06:34:43
 Re: FERG MODEL 20 WITH NO GENERATOR in reply to FRED MABEY, 02-27-2002 15:17:51
I made a alt. bracket for Delco as follows.
You need a piece of strap iron 1/4 by 1 1/2 about 18 inches long to start. Cut 2 pieces 4" long exactly. Put one of them where your front generator bracket would be. It will be pointing straight up. Scribe where you want the hole drilled. Now drill both pieces at the same time . this way the top will be level. Cut off a piece about 4" long and lay it on top of the verticle 2 pieces . Cut 2 more pieces about 1" long . These 2 Pieces will be the ears that bolt to the alt. Bolt them to alt and set it on the horizontal piece on top of the 2 vewrticle pieces. Square it up for belt alignment and tack it together with welder. Take it off and weld it solid and trim off excess hioizontal piece. Go to junk yard and get a bracket for top of alt to adjust belt tension. This bracket bolts to top water pump bolt. Looks factory and is simple to make.
Mark Hendershot
02-27-2002 17:00:29
The TO-30 mounts to the side of the block in pre/drilled and treaded holes in the casting with a bracket. You might be able to adapt a TO-30 Gen but it will take some home made bracket to do so. The TO-20 used a bracket off the axle assembly bolt holes on the block and used a different style generator also. If you need a picture of the brackets and generator e-mail me. Mark H.
