Help locating a seal
NCtim
03-03-2002 13:02:23
1949 TEA-20. Later model engine. 85mm bore. Don't know the tractor's serial #. I had new seals installed on my axles by the local dealer who also included the outer seal (2.865" dia). What I need is the inner seal which sits inside a race measuring 4.25" just at the end of the trumpet. Any ideas on where to get this? I'll try to include a picture if it works.
NCtim
Pete Tatham
03-04-2002 02:40:20
 Re: Help locating a seal in reply to NCtim, 03-03-2002 13:02:23
Try your local MF dealer. The part number for the inner seal you require is 104628. If you have no luck locally I can supply you with the seals from the U.K.
Pete.
NCtim
03-10-2002 15:03:28
 Re: Re: Help locating a seal in reply to Pete Tatham, 03-04-2002 02:40:20
Well I went to the dealer and he says that part number doesn't compute. I took my manual, which doesn't show a seal there, and he decided that there isn't a seal at the flange on the English TEA-20. Can anyone confirm?
Thanks,
NCtim
