Correction rotation
Bill H.
03-08-2002 17:45:46
I bought a 13-4011-sw 12 volt alternator from NAPA to do a conversion on my TO 20. I think I have a problem with the rotation. If I'm facing the alternator front the cooling fins are slanted toward the left - what I would think would be a counter clock wise rotation. If I look at the generator from the front as it rotates on the tractor it is rotating clockwise. My question is this if both rotations are opposite can I use this alternator or should I try to return it and get one where the rotation is the same as the engine rotation. Bill H
marlowe
03-09-2002 10:19:48
 Re: Correction rotation in reply to Bill H., 03-08-2002 17:45:46
a little late with a reply but yes it will like the others have said. happy charging
Bill H.
03-09-2002 09:46:14
Thanks everyone. I guess this was a dumb question but I just wanted to be cautious.
Duner Wi
03-09-2002 04:59:37
Reverse rotation marine engines as well as Corvairs run so called backwards. Some industrial applications used in dusty conditions may have a fan that moves air opposite from normal. Alt. does not care which way it runs as far as charging is concerned.
twopop
03-08-2002 20:34:09
yes,an alternator will charge in either direction,however all automotive engines turn clock wise and so do the alternators.
Pete@easttn
03-09-2002 08:02:38
 Re: Re: Correction rotation in reply to twopop, 03-08-2002 20:34:09
(ALL) automotive engines turn clockwise?
marlowe
03-08-2002 19:00:39
the rotation will be right. some pull air some push to cool
Bill H.
03-08-2002 19:44:09
 Re: Re: Correction rotation in reply to marlowe, 03-08-2002 19:00:39
Marlowe, are you saying that this alternator will charge in either rotation direction. Bill H
