Governor TO-30
Steve in Ohio
03-21-2002 14:35:21
Just replaced bearings&seals on the governor shaft of a To-30,looking for advice on getting the proper adjustment of the governor linkages.The engine starts and runs fine but will only go up to 1600 RPM,at that point the throttle lever moves back towards the low speed position.
Ray,IN
03-21-2002 21:20:59
 Re: Governor TO-30 in reply to Steve in Ohio, 03-21-2002 14:35:21
I emailed you the detailed instructions from the owners manual. You will benefit from purchasing one from a MF dealer. It contains everything you need to know for operator servicing.
