Electronic Ignition, Genesee Products, Everything OK!!!
NCtim
03-23-2002 10:20:22
Hi All,
Got it fixed! Andy's statement (Genesee Products),
"The module is fairly forgiving of magnet sleeve elevation. If the bottom of the sleeve is approximately even with bottom of the module, all should be well.", was key to the whole problem.
The module is NOT forgiving of magnet sleeve elevation. I made a plate the approximate thickness of the difference in sleeve/module alignment and installed it under the module plate. Everything fires as it should now. The sleeve and module line up within a 32nd of an inch.
I believe Pertonix might want to include a spacer for the module plate also in their kits. Without someone like Andy at Genesee Products who has the knowledge and patience to help the customer, this transaction would've been a total loss.
I'm a really happy tractor guy today. It's stopped raining and the sun is out. Almost 40 degrees. The wind has died down to about 10mph and shifting from the south. Looking for sixties tomorrow and calm!
NCtim
