Ball Joint
Newguy
04-01-2002 13:43:54
Hi!
I read on another website that Harry Ferguson invented the detachable ball joint. Was this used on the TEA, and how do they "detach"?
George
04-06-2002 12:00:35
 Re: Ball Joint in reply to Newguy, 04-01-2002 13:43:54
Yes the ball joints are at either end of the lower link arms, they side on to pins on the axle casing and retained by castellated nuts and splitpins at onto implements at the other end and retained by lynch pins. They are also used on some top links. When they become to worn to be serviceable they can be renewed with weld on replacements saving the cost of a complete arm
George
Jack M, UK
04-04-2002 15:58:34
The only place where I have seen early "detachable ball joints" is on a spec photo of a Massey Ferguson 165.
They detached about 1 inch away from the actual ball, so that cat2 ball joints could be fitted.
Don't think ANY were made for fergies because they all used cat1 ball joints!
Regrds
Jack M, UK
