Ferguson TO-35 govenor problem
Dan F Knoxvill
04-08-2002 10:08:41
I have a 1955 Ferguson TO-35 (gas continental engine). Tractor sat unused in shed most of winter and now seems to have a problem with govenor. When pulling a yardbox engine will load down almost to the point of stalling before govenor will bring engine speed up. Also if choke linkage is pushed all the way in tractor will idle down to a stall. I feel this is a simple problem but am new to tractor maintenance so any assistance would be appreciated.
Doug
04-12-2002 09:54:07
 Re: Ferguson TO-35 govenor problem in reply to Dan F Knoxville Tennessee, 04-08-2002 10:08:41
I had a similar problem one spring after the tractor sat for a long time, and the main jet in the carburator was clogged. Its the brass part that sits close to the bottom of the bowl. Had to take it apart, and push a wire through the tiny orifice to unclog the debris/varnish that develops when it sits. For me, the symptom was that when the tractor was accelerating or loaded down, that it would start to kill unless I choked it.
