12 volt conversion on a TO-20?
george
11-04-1999 19:12:00
I just bought a TO-20 at an auction, looks good, runs good, except, its not charging the battery. A closer look and I see I have a 12 volt battery on a 6 volt sytem. I am interested in converting to a 12 volt system but can not find a conversion kit. Anyone know where I can find one? I can find an 8N 12 Volt conversion kit, will that work?
SandyB
11-21-1999 12:05:18
 Re: 12 volt conversion on a TO-20? in reply to george, 11-04-1999 19:12:00
George,
At the top left of this page is "Parts and Supplies". Click on that and then scroll down to Genesee. Click on, that and read the article about 6 volt to 12 volt conversion. Pretty good article that covers it well. Hardest part is making the bracket for the alternator. I did mine myself...if I'd known about this earlier, I might have used theirs.
Good luck.
Sandy
Paul
11-08-1999 07:33:15
George - Stevens Ag Parts (1-800-333-9143) has a conversion kit that will fit your tractor. Cost is $169.95.
Paul
george
11-14-1999 17:18:35
 Re: Re: 12 volt conversion on a TO-20? in reply to Paul, 11-08-1999 07:33:15
Thanks for the tip Paul. I installed a 6 volt battery to get my tractor running, had the generator tested, it is good, I bought a new regulator, still doesn't charge the battery. I think I'll go ahead with the 12 volt conversion to fix this problem
Clarence Carhill
11-30-1999 19:31:21
 Re: Re: Re: 12 volt conversion on a TO-20? in reply to george, 11-14-1999 17:18:35
Should you ever restore your little grey Fergie it would be a lot better to leave it with the 6 volt system. Maybe your battery is to low to accept a charge or its got a bad cell. I would charge it and then test it with a load tester. A volt meter will tell you the voltage going in and out the battery.
