Compression
Newguy
04-25-2002 00:07:56
Hi!
What is the manufacturers recommended compression (in psi) of an 80mm bore TEA. I did a test and got all nicely around 70psi,but all 4 cylinders could have burnt rings, valves, etc evenly.
Peter Tatham
04-25-2002 01:18:38
 Re: Compression in reply to Newguy, 04-25-2002 00:07:56
At cranking speed, the cylinder head pressure of an engine in good condition should be 90 to 100 lbs per square inch.
