Coil wiring
Joe(NH)
04-29-2002 14:23:26
the ferguson TO 30 i just purchased had it's electrical ground changed from the original positive ground to a negative ground...i dont think any other change was made..at least that i can tell...i have switched it back to a positive ground..now for my question..... does the wire on the positive of the coil now need to go to the post of the distributor housing..and the negative post wire go back to the ignition switch?....the original ignition switch is missing, there is a toggle switch in its place,not doing anything i think...thanks for any help..... ....the engine does crank , but wont fire up....it sat for over ten years
Duner Wi
04-29-2002 18:38:59
 Re: coil wiring in reply to Joe(NH), 04-29-2002 14:23:26
The + on the coil goes to the dist post on pos. gr. the opposite is true for neg. gr.
Joe(NH)
04-29-2002 15:11:56
my apologies tim...i should have mention it has the original 6 volt system....i hope my original post is not to confusing.....let me ask it this way..... .....if the system is positive ground,does the wire between distributor and coil need to bo on the positive post on the coil
NCtim
04-29-2002 14:38:54
Joe,
All 12 volt systems are negative ground unless you have the original GENERATOR marked 12 volt positive ground. What does your manual say? If it specifically speakes about the 12 volt positive ground system then you're doing it right. The positive side of the coil goes to the ditributor.
If you have an ALTERNATOR it's highly unlikely that it's positive ground (very expensive), unless it's specifically marked, . Alternators are negative ground and if you hook it up otherwise you'll ruin it, the battery or both.
BE SURE!!!
