Carby seal
Andrew
05-04-2002 19:20:49
Hi!
Is there supposed to be an o-ring seal on the Zenith carby, in the inlet which faces out to the side of the tractor. On mine, the fuel pipe goes in here, and I have been getting a leak.
Thanks in advance!
Phil (VA)
05-07-2002 10:48:18
 Re: Carby seal in reply to Andrew, 05-04-2002 19:20:49
If I understand correctly, you are asking about a seal where the gas line connects to the carb. I don't have a Zenith, but on the M-S I believe there is a small gasket on the fitting where the gas line connects to the carburettor.
