REBUILD INFORMATION
PHIL
05-06-2002 19:50:56
I HAVE A FERGUSON TRACTOR THAT CAN ONLY RUN FOR AN HOUR BEFORE FOULING PLUGS FROM BURNING OIL. MY QUESTION IS; IS RE-RINGING THE ENGINE AN OPTION OR TOTAL REBUILD? THE SERIAL # BEHIND STEERING WHEEL IS TD 83215 . THE ENGINE *Z129A800N CAN YOU ALSO HELP ME IDENTIFY WHAT YEAR AND MAKE THIS IS ??
Chuck (CA)
05-06-2002 21:18:30
 Re: REBUILD INFORMATION in reply to PHIL, 05-06-2002 19:50:56
Well, Phil,
first of all, it seems you have a 1952 TO30. The Z129 was the Continental engine used for the TO30's. See the link below regarding serial numbers.
Your problem could indeed be rings, but valves might also be the culprit. A shadetree way of figuring out is with both a dry and wet compression test. I'll try and make this short:
1. Remove all sparkplugs and disconnect coil wire.
2. Do a compression check on each cylinder and write down number.
3. Put approximately 2 tablespoons in each cylinder and do second compression test and compare numbers. This acts as a temporary seal for the rings.
If the compression significantly increases after adding the oil (wet test) it's a good indication that your rings have had it. If the numbers stay about the same, then your valves are shot.
If you do need new rings, I would reccommend doing the whole shebang, which is easy for me to say, because it ain't my wallet. While you have the head off, look REAL closely between the cylinders for ANY sign of hairline cracks. However, if you did have any cracks, you would probably know by now, because of oil getting in your coolant.
I hope I helped and that what I said makes any sense. If not, I'm sure some of the old pros out there decipher it for you.
Good luck,
Chuck
Fred Martin
05-10-2002 07:00:26
 Re: Re: REBUILD INFORMATION in reply to Chuck (CA), 05-06-2002 21:18:30
Whenever I see someone giving directions on how to run a compression test on an engine, it seems they leave out one important thing. As I recall, it calls for WOT (wide open throttle) to open the carburator butterfly to let in some air so that theres something to compress. Any of you mechanics ever try it both ways to see if theres a difference? I haven't but this is how I was taught to do a compression test. Fred Martin, Greenfield, Ohio
Chuck (CA)
05-10-2002 18:35:10
 Re: Re: Re: REBUILD INFORMATION in reply to Fred Martin, 05-10-2002 07:00:26
Hi Fred, I heard the same thing, but since this is a governor system which a regular car is not, I don't think it matters. Once again, though, someody with more knowledge is more than welcome to disprove me.
Chuck
