Cast Iron in tank
Bubba G.
05-15-2002 19:57:02
Took the tank off my 53 TO30 someone has cut a square out in bottom side of tank and put a large flat cast iron plate inside tank and welded shut . I can see where the weld has been patched with JB weld over the years. Was this to keep fuel from boiling ? I was going to Use Kreem Tank Sealer to seal tank but now not sure what to do because the plate slides around Thanks for any advise. Bubba
scott morrow
05-16-2002 16:26:11
 Re: Cast Iron in tank in reply to Bubba G., 05-15-2002 19:57:02
If the tractor is in good shape or even if it isn't save your self time and headaches.Go to ebay type in ferguson tractor serach titles and descriptions there is a brand new gas tank up for auction its for a to 20 but is the same as a to 30 starting bid was around 70.00. good luck
Bubba G.
05-17-2002 19:04:36
 Re: Re: Cast Iron in tank in reply to scott morrow, 05-16-2002 16:26:11
Thanks Scott, Your right about tank, P.s Thanks for telling about parts on ebay. Bubba
Bubba G.
05-17-2002 19:02:18
Thanks Scott, Your right about tank, P.S Thanks for telling about parts on ebay. Bubba
