Final drive/hydraulics for TO-30
Greaseman
05-19-2002 16:31:04
what oil should I use in the final drive and hydraulics of my TO- 30?
Ray,IN
05-19-2002 20:11:40
 Re: final drive/hydraulics for TO-30 in reply to Greaseman, 05-19-2002 16:31:04
Use 80/90wt. straight mineral oil. Straight mineral contains NO ADDITIVES that will ruin your hyd. system. Remove all three drain plugs or you won't remove the last 1/2 gallon from the other two areas, and this contains the gunk and water that settles out. The MF oil Phil wrote of is straight mineral oil.
Phillip J. Fenner
05-19-2002 17:24:46
M1103 ,MF8417118M1 at your friendly MF dealer or Ford M2C-134D will work.
