Will an 8N radiator fit a TO20, and is ther an exhaust gasket?
murphy
05-22-2002 10:25:51
My local tractor supply sell after market radiators for 8n,9n and it looks a lot like my TO20 radiator, are these close enough to change out? It would be nice to know there is a local supply just in case.
Also is there supposed to be a gasket between the block and the exhaust manifold on my TO20, there is some blow by and I cant tell if there is or ever was any gasket in there.
Fred OH
05-24-2002 08:35:32
 Re: Will an 8N radiator fit a TO20, and is ther an exhaust gasket? in reply to murphy, 05-22-2002 10:25:51
A measurement of one compared to the other as far as physical dimensions and hose sizes and location would be required as well as removing the inside top bracket/brace that is on the Ferguson and solder it on the Ford radiator. (There would go your warranty) Ford doesn't have this brace. Also the mounting holes on lower front must be similar same. Sounds like too much work to me, I would go with the other Fred and get the ones designed to fit. I bet with a name like Fred, he even has a good price. Fred OH
Fred
05-22-2002 18:24:49
I have manifold gasket and new radiator for TO 20.
