TEA-20 fuel shut off
Morty- Alberta
05-22-2002 16:04:32
Was using my TEA on the weekend- it has as far as I can tell the original shut off and sediment bowl and the vibrations were causing it to turn itself shut and starve the engine of fuel. Is there any repair for this or should I just replace it with a new one and if so how much is it going to cost ?? I use the beast so originality isn't a real issue I can always try to use one off the old 8n's sinking into the ground in the back 40
Jone
05-23-2002 15:39:12
 Re: TEA-20 fuel shut off in reply to Morty- Alberta, 05-22-2002 16:04:32
Hi Morty
you can fix this problem, by tighten the fitting(?) around the shaft. there`s a leather gasket in there, and when you thighten this, it will be harder to turn it.
http://www.traktordelar.nu/mf2/fe20-brfilter.htm
