Electrical Connection of TAC on Ferguson 1951 Tractor
Bill H
05-24-2002 06:16:55
Can anyone tell me how to connect a Tac to the breaker points and condensor electrical system on my tractor? I need to monitor the RPMs so that they don't get too high. My RPMs gradually creep up or slow down during operation. I may be trying to fix a primary problem with a secondary solution. Thanks Bill H.
Duner Wi
05-24-2002 12:52:50
 Re: Electrical Connection of TAC on Ferguson 1951 Tractor in reply to Bill H, 05-24-2002 06:16:55
Normally this would hook up to the wire that goes from the coil to the dist. In other words the dist. side of the coil.
Bill H.
05-24-2002 19:46:08
 Re: Re: Electrical Connection of TAC on Ferguson 1951 Tractor in reply to Duner Wi, 05-24-2002 12:52:50
I have change the wiring to 12 volt - ground. The battery (hot) wire from the ignition switch (cold side)is connected to the + side screw attachment on the coil. The - side screw of the coil is wired to the post just below the distributor cap. If I follow you this is where the TAC feed wire should be connected. Bill H.
Duner Wi
05-25-2002 09:53:37
 Re: Re: Re: Electrical Connection of TAC on Ferguson 1951 Tractor in reply to Bill H., 05-24-2002 19:46:08
Hook to the - side of the coil or to where the coil wire attaches to the dist. Either way should work.
