Kigass pump
Andy
05-29-2002 18:22:36
third party image
I recently bought a 1954 TEF20 which has the Standard diesel engine. It runs well. It is missing some of the cold starting equipment. It has the pre heater control glow plug in the intake manifold which works well. Missing is the Kigass pump and Kigass tank which sprays atomized fuel into another port above the glow plug.
Does anyone have a picture of this unit that they can post or email me.
Also where can I buy this unit?
Andy
I've posted a few picture of the tractor. I hope the link works.
jean-christophe
06-13-2004 01:18:42
 Re: Kigass pump in reply to Andy, 05-29-2002 18:22:36
third party image
I found an old kigas system on e-bay. My TEF did not have it. This system works perfectly even with a small leak. But honestly, with my engine completly new, it is not necessary to use it above 0° celsius
LES KIGASS EMPLOYEE
04-17-2004 13:57:55
REFERENCE O RING FOR KIGASS PRIMER PUMP TRY KIGASS AERO COMPONENTS MONTAGUE RD WARWICK THEY STILL CARRY SMALL STOCK OF PARTS AND DO REPAIRS TO SOME PUMPS
Peter, U.K.
05-30-2002 00:46:48
Andy, As you probably know, Kigass cold starting equipment for TEF's is no longer manufactured. Your best bet is to contact tractor breakers. If you are in the U.K. e-mail me and I'll give you a few useful contact numbers. You could also advertise on the FOFH web site.
Peter.
LES
04-17-2004 13:52:03
 Re: Re: Kigass pump in reply to Peter, U.K., 05-30-2002 00:46:48
KIGASS PRIMER PUMPS CAN STILL BE BOUGHT AT KIGASS AERO COMPONENTS MONTAGUE RD WARWICK THESE PRIMERS ARE ALSO REPAIRED BY THE ABOVE.
LES
04-17-2004 13:39:41
Andy
05-30-2002 01:57:30
The manual I have does not show a picture of the pump but makes reference to it. The principle behind it is straightforward - to spray a fuel mixture into the manifold where the glow plug is to give a warm starting mixture. I'll search around for a used one.
Do you know where there might be a picture of one on another tractor?
Andy
Phil
09-26-2003 00:24:55
 Re: Re: Re: Kigass pump in reply to Andy, 05-30-2002 01:57:30
I have managed to find a ki-gass pump for my '53 tractor, but it leaks !! The little square cross-section 'O' ring on the piston has perished and gone. Can anyone tell me where to find such an 'O' ring..... .... I've explored every supplier I know without success.
Thanks
LES KIGASS EMPLOYEE
04-17-2004 13:51:14
 Re: Re: Re: Re: Kigass pump in reply to Phil, 09-26-2003 00:24:55
REFERENCE O RING FOR PRIMER PUMP KIGASS PART.
TRY KIGASS AERO COMPONENTS MONTAGUE RD WARWICK. STILL CARRY SPARES FOR PUMPS ALSO DO REPAIRS.
bodger
09-25-2003 16:45:13
I found a good article on the Ki-Gass system on a French site: perso.wanadoo.fr/richardleroy/MF835DS/KiGass.htm
Gentlemen, to the dictionaries!
