Disk with draw bar or 3-point
Nick
06-04-2002 09:53:43
I have a Ferguson TO-20 and a disk with a quick hitch. Am I better off modifying the disk to be pulled by the belly mounted draw bar or by a conventional 3-pt arrangement? The disk is two row, probably weighs 600 lbs and has a fixed angle (can't be straightened for towing with out cutting). This is the main reason I want to use the 3-pt so that I can lift it to move it. Also, is rollover a concern while using it or will it ride up and over obsticals?
