35 head light
Terry
06-15-2002 19:00:28
I am having trouble getting off one of my head lights. have been soaking the nut with oil with no luck. I am about to cut off, but since it is a speacial bolt with a hole for wires I have held back. are these bolts available alone and if not I suppose the headlights are with the bolts? I am taking off the headlights to restore and paint the hood. Thanks for any advice. Terry
David
06-15-2002 21:21:57
 Re: 35 head light in reply to Terry, 06-15-2002 19:00:28
Can you get access to split the nut with a nut splitter and leave the bolt alone? If you're going to be painting anyway you could almost certainly get it off easily if you can apply enough heat but you'd need equipment like oxy propane to do this. Is taking part to someone with gas equipment an option?
David
06-15-2002 21:17:25
