Manifold
Andrew
06-16-2002 12:32:03
Hi!
Could my TEA's manifold be blocked up, thereby causing a miss on one cylinder? I have a constant pop pop pop sound which sometimes happens, sometimes not.
Thanks in advance!!!
rod
06-16-2002 18:50:07
 Re: Manifold in reply to Andrew, 06-16-2002 12:32:03
make sure plug wires are on correct plugs rotation of distributor is counter clockwise on the TEA often folks get the plug wires on wrong and yet they will run like that.
regards
rod
H.T.Hertz
06-16-2002 14:30:11
- sure it isn't just a fouled up plug? If it has been idling for some time or working light load, it tends to build up carbon deposits. Clean or replace the plugs & see what happens... - just a thought..
Henning
