3pt hitch went up by itself
Dennis
06-21-2002 07:13:50
My TO20 Massey went over some rough ruts forcing the flail mower to move up. When this happend the mower continued to rise to the top by itself.
The pressure at an allenhead plug on the side of the case will allow the oil pressure out. Or after a while it will go down by itself.
I think a slug of gunk went into the raise/lower
valve. If this is the case where do I start?
Carnack
07-09-2002 08:07:18
 Re: 3pt hitch went up by itself in reply to Dennis, 06-21-2002 07:13:50
Look in the dipstick cover and you'll find linkage for the hight control. The pin fell out. Also you will find other pins which fell out before in the oil drain under the pump. Finally you will be a very rich man soon!
