Generator
Brian G
06-21-2002 23:13:39
i have a to20 and the battery goes dead after about a week of starting and running it i have had the generator rebuilt which they said it needed they have checked it once again since then they say it is fine i have had the voltage regulater checked they said it was putting out to many volts they adjusted it and they charged my battery but it still goes dead should i replace battery and regulator im at a lost thanks for your help
marlowe
06-22-2002 19:25:08
 Re: generator in reply to Brian G, 06-21-2002 23:13:39
is the battery put in right it should be + ground
TOKRUYS
06-22-2002 06:07:14
It sounds like the battery is bad. You can have it checked too, either with a Load Test or just with an electrolight check to indicate if you have a bad cell or not. If it's not that then you may have some bad wiring... Good luck.
