Gas
bgraves
06-23-2002 21:25:18
my to20 has been boiling the gas in the gas tank i never noticed this until the tractor started acting funny i pulled out the choke and it runs fine can some one help me as to why this does this
marlowe
06-24-2002 19:34:45
 Re: gas in reply to bgraves, 06-23-2002 21:25:18
any one with a to20 or to30 will see this if they work it hard in hot weather and the gas is low in the tank. the thing is that not many look in the tank but the ones that do this is what they will see mine has been doing it since 1949 also gas has a low boiling point. it will take some one smarter to tell what it is ?
Ford Man
06-24-2002 06:56:24
Not much of a carb. man but if you have to pull the choke to keep her running , then you are not getting enough fuel . Check your fuel flow at the carb.. Also check the carb. adjustments . I would recomend an I & T shop manual . Available at MF dealers and Tractor Supply , etc. . Mine has been a big help on my TO-30 .
As far as the boiling gas , seems like I have seen this discussed before but I don't remember the outcome . You might want to check the archives .
By the way . My last name is Graves also . Where are you from ? I am from NC .
Ford Man
Frank Light
06-24-2002 11:26:10
 Re: Re: gas in reply to Ford Man, 06-24-2002 06:56:24
Hey! I'm from NC too! Where ARE you guys from? I live just west Madison in Stokes County. I'ts about 20 minutes south of the VA line in the center of the State. Yee Haw!
Ford Man
06-24-2002 13:46:56
 Re: Re: Re: gas in reply to Frank Light, 06-24-2002 11:26:10
I'm from Asheboro , about 30 miles south of Greensboro . My Dad's people are from Seagrove which is about 15 miles south of Asheboro .
Ford Man
bgraves
06-24-2002 22:36:33
 Re: Re: Re: Re: gas in reply to Ford Man, 06-24-2002 13:46:56
im from missouri
