TO-35 stuck in 2nd gear
BW Williams
07-07-2002 07:44:32
My '55 TO-35 got stuck in 2nd gear the other day. No amount of force on the shift lever would budge it. So I removed the fill plug and jimmied the shifting fork with a long screw driver and it's works for now. Talked to an old farmer friend and he said it was a real common occurence if you pull up on the shift lever while shifting. Probably been discussed here before, but thought someone might need the info. Sure apprieciate the input from everyone here! BWW
