Flushing rear/hydraulic/trans onTO20??
Chris
07-11-2002 12:24:41
I've drained the fluid from all 3 plugs to change axle seals... By looking down thru the filler hole, I can see that things are pretty "gunked up" in there.. What's the process (if there is one) for flushing this stuff outta there?? What solvent is safe to use??
John, IN
07-11-2002 19:41:20
 Re: Flushing rear/hydraulic/trans onTO20?? in reply to Chris, 07-11-2002 12:24:41
Well Chris, I have been told that diesel/kerosene are not good for the hyd. system. They have the additives that will eat your seals. Also they will stay on a bearing and cut it's life short. To be on the safe side I would and did use a good citrus cleaner. Cut it with hot water spray, as much as needed, rinse with hot water. Use a air gun to dry. Does a real good job.
Andrew
07-11-2002 16:13:57
Hi!
When I drained my trans axle case to change the pto, I refilled it with diesel, and then drove around for a bit to wash it around, then drained it. I did this twice, and it did the job.
Chris
07-11-2002 18:56:14
 Re: Re: Flushing rear/hydraulic/trans onTO20?? in reply to Andrew, 07-11-2002 16:13:57
When you flushed with diesel, did you fill it with 6 gallons?? How long did you drive it around??
Chris
07-11-2002 18:52:55
I thought I read someplace that I could use diesel fuel!! I'll give that a shot!! Thanks for your response.
Phil (VA)
07-11-2002 12:49:08
I've used kerosene successfully. But I doubt it will flush it completely unless you go inside and scrape by hand.
Chris
07-11-2002 18:54:42
 Re: Re: Flushing rear/hydraulic/trans onTO20?? in reply to Phil (VA), 07-11-2002 12:49:08
I suppose it wouldn't hurt to try it.. I think I'm going to take Andrew's advise and use diesel and flush and drain it twice..
Phil (VA)
07-12-2002 11:28:33
 Re: Re: Re: Flushing rear/hydraulic/trans onTO20?? in reply to Chris, 07-11-2002 18:54:42
When I have used kerosene to flush it I have not filled the tractor, nor driven it, nor used the lift. I just flushed it and used my hand and scraper to pursuade the gunk toward the drain. I have not put kero in the pump, etc.
