Front mount hydraulic pump
Ron Penrod
07-13-2002 19:44:10
Does anyone know were I can get parts to put a pump on the front of the tractor so you can use the loader with the clutch in
ger
08-10-2002 14:46:16
 Re: Front mount hydraulic pump in reply to Ron Penrod, 07-13-2002 19:44:10
hi rod, mine,s a tea 2085 1954 has a front mount pump and a loader when i got it , it had a disc bolted to the pulley on the crank with a gear (TOOTH) design cut into it and a shaftwith a gear welded on a shaft it worked well for a long time but eventually broke an for years after that i had nothing but problems with it ,mainly for lack of proper parts and a system.eventually i have something that works pretty well . its a disc with four bolt holes in it to bolt to the pulley a hub in the centre that accepts the shaft with a woodruff key cut into it an two set screws, the shaft is 11 inches long runs through the axel out the front an bolts up to a front mounted pump through a flex coupler,the pump is mounted on a frame bolted an welded to the front of the tractor, on the ends of the pump shaft an the other shaft are two flanges for bolting to the coupler. i have everything made at a local machine shop,as long as everything stays tight it works fine once you get play in it it wears an eventually breake so i have extras made up and am getting fairly good at changing them usually every 3to 4 years depending on use. hope somebody on here come on with a better system, mine works but it certainly be improved . hope this of some help to you later ger
