Manifold Gasket
Andrew
07-21-2002 12:52:02
Hi!
Is it possible that my TEA's manifold gasket is leaking on the valves on one cylinder? Could this cause a "pop" in the exhaust?
Richie Magoo
07-22-2002 20:08:51
 Re: Manifold Gasket in reply to Andrew, 07-21-2002 12:52:02
Nay....that wouldn't cause a pop. Could be: A burnt valve, bad cam shaft, worn part in valve train on the affected valve, or a lot of carbon on the valve, causing it not to seat properly.
None of these are a particularly fun prospect! (I assume the tractor is in good tune, with all good wires, points gap properly set,etc.?)
