TO-30 Main Bearings
Badgerwy
07-28-2002 12:52:52
Iwas hopeing some one could shed some light on the main bearings on a to -30.In the ferguson shop manual it states that the to and te-20 had a single flange front main bearing.it also states the 30 had a streight shell front main bearing.i have a to-30 that i am rebuilding. the front main bearing in my to-30 has a lip on the back side that sholders to the block.this looks like a flanged front bearing to me.but according to the manual the 30 didnt have a flanged front bearing.it someone could clear things up for me id appreciate it .also the crank is marked z-129 so i dont think it is the wrong crank thanks in advance Badgerwy
Duner Wi
07-29-2002 19:35:31
 Re: TO-30 Main Bearings in reply to Badgerwy, 07-28-2002 12:52:52
Sounds like you have TE TO 20 style main bearings. Makes no difference as long as you use the appropriate thrust washers.
