HUPP tranny is ka-put.
Dick
08-03-2002 18:53:50
Split the to-20 today. The HUPP tranny has a nasty crack right next to the drain plug on the bottom. Not the first time tranny went south, there is about 5#`s of welding rod on the tranny case. Question is, how does one get the HUPP out of the tractor? Took the four bolts out of the front piece of the tranny, where the input shaft carrier bearing would be. can not pull housing off the shaft. Would broken parts in tranny keep it from coming apart? Found a used tranny for $550.00, would it be better to put tractor back to orgininal? Thanks in advance for any and all help. Dick
