Foud id tag
td-9
08-11-2002 17:41:11
it is on the motor,says ----- --46700A----if im reading it right.should this be the same as the tractor? if so this is a te, right? are they harder to get parts for? thanks for any help. I normally deal with dozers, just fell into this thing for a good price.
Paul in California
08-11-2002 21:18:14
 Re: foud id tag in reply to td-9, 08-11-2002 17:41:11
I hope there is some letters before the 46007A on the engine or you may have something else. Take a scraper and a wire brush to the serial pad and clean off all of the piant and grease. Then post all of the letters and numbers as they appear on the pad. It could be a TE,TO,TEA,TEB,TEC,TED, TEE,TEF,TEJ,TEK,TEL,TEM,TEP,TER,TES,TET. with out the rest of the information it will be useless to even help or even give an accurate answer to any of your question.
