Hood pivot bolt size
Bill B CA
08-16-2002 18:44:35
Mine are gone. Need the size and tpi of the originals,
Were the nuts welded in the frame? Or was the bracket or frame tapped. Were different nuts and bolts used on TO's
and TE's ? Thanks
Fred OH
08-20-2002 09:10:31
 Re: Hood pivot bolt size in reply to Bill B CA, 08-16-2002 18:44:35
I had to make a new one for my tractor once...seems to me that it was 7/16" X 20 National Fine threads (TO-20)...it is a shoulder bolt that has a shoulder diameter on it that is slightly smaller than the hole going through the hood extension...length of shoulder is so that it will bottom out before hood gets tight against mating part. To find out if this is what you have...try a bolt in the threaded hole. Seems like I remember 11/16" hex stock (mild steel)was what I used. A front lawn mower axle bolt would be a great place to start...if you got a friend that has a lathe to do the rest...(The hole is threaded.) Or a regular bolt with a bushing on it of the proper length would work just as good. Otherwise...a tractor salvage yard is your answer. L8R....Fred OH
Jim W
08-19-2002 12:42:19
What tractor do you have?
Jim W
Bill B CA
08-19-2002 15:30:11
 Re: Re: Hood pivot bolt size in reply to Jim W, 08-19-2002 12:42:19
Jim It's a model TO30 Ferguson. Still wondering about any differance in thread on TOs and the TEs.
Thanks
