TO 30 carb
Pat Woodruff
08-26-2002 13:25:55
Does anyone know where I can get an exploded diagram of the TO30 carb? How can I tell if this is TSX361,TSX361A or a TSX458? The first two are for a 20 but maybe the carb was switched. I told the dealer to send me a rebuild kit for the TO 30 carb and the power jet that came in the rebuild kit is a different style than the one I took out of the carb. The old one has threads on the top and the replacement is threaded at the top and bottom.
Last question, is there a screw type fitting at the bottom of the power jet well?
Thanks
pat woodruff
08-26-2002 17:03:51
 Re: Re: TO 30 carb in reply to k e siladi, 08-26-2002 16:32:34
Thanks! I have to figure out which jet goes in the bottom. Obviously the parts kit is a little off! I'm going to check with Roberts Carb back in Ohio and see ifd he might have the parts around.
Pat
k e siladi
08-27-2002 16:46:48
 Re: Re: Re: TO 30 carb in reply to pat woodruff, 08-26-2002 17:03:51
F.Y.I. - I used an old wire type spark plug gauge to measure the diameters of the jets, old and new. Just matched them up !
