Cold starting
Mike
09-01-2002 11:18:40
My TE20 fires right up using the starting handle even having been left for mounths. Trying to start it when warm however is a bloody nightmare!
Any tips are much apreciated, (how wide should I open the throtle?, any choke? etc)
Fred OH
09-03-2002 11:33:29
 Re: cold starting in reply to Mike, 09-01-2002 11:18:40
Each one of these engines has it's own personality and I have a saying about it. "You have to get smarter than the metal". Mine does the same thing as yours...and I find that no throttle at warm starting is it for me...which tells me that the electrical is probably a little weak. If you had to choke it at warm start up...it might be telling you that the fuel is a little lazy about getting in there. These tractors do require that you think. Just need to get your thinking like an engine thinks. (smile) L8R....Fred OH
Duner Wi
09-01-2002 15:28:49
This is the way my TO 20 works when hot. Throttle about 1/4 open , ign. sw on, pull choke out, work start lever forward, Mine starts on first turn but if it does not push choke in after 1 turn or it will get too much gas. Should start on second turn.
Norm
09-01-2002 12:33:52
Sounds like your carb is set way too rich however you didn't mention if you used choke when you tried after a long time period. Give more details; black smoke ? Another possibility could be your condenser, check if it fires at plug when she won't start.
Hope it helps
Norm in Ont.
Mike
09-05-2002 12:40:49
 Re: Re: cold starting in reply to Norm, 09-01-2002 12:33:52
Thanks guys, I shall try some of your suggestions
