Fluid type
jim k
09-05-2002 17:15:39
I have a To-20 1949 and would like to know what type oil to use in gearbox for tranny rearend & hydraulics.
Norm
09-05-2002 19:20:46
 Re: fluid type in reply to jim k, 09-05-2002 17:15:39
Jim, Ferguson states to use 80 - 90 wt mineral oil, a MF dealer would carry this as MF1103 i believe. I know there are lots of opinion out there but this is what is recommended by MF.
Also for engine you should use non detergent oil with weight depending on season. Summer = 30
Winter = 10. The non detergent is recommended unless you had a complete recent engine rebuild with all new seals then a regular multi viscosity oil can be used.
Good Luck
Norm in Ont.
Gregg/Ohio
09-07-2002 19:16:55
 Re: Re: fluid type in reply to Norm, 09-05-2002 19:20:46
Note on engine oils: Use 1950's oils, you can count on 1950 engine lifespans. Fact:Use of todays great oils,IE: Dino/Synthenics.You will never crack that engine apart.(I have yet to see 1 drop of leakage under my engine) Can not speak for all,but I would never go back to a bygone era, for engine lube.
Terry
09-05-2002 18:03:49
Jim you just opened a can of worms. FYI you should review the archives of this board to find out why I said that. Look under transmission fluids or oils. Believe me the answer is there!
