Camshaft
jim (ky)
09-10-2002 19:53:46
With a reground camshaft do you have to change cam bearing size? thanks very much. Jim
Willy-N
09-13-2002 23:51:44
 Re: camshaft in reply to jim (ky), 09-10-2002 19:53:46
There are no bearings used for the Camshaft on the TO-20 or 30 engine. Mark H.
Duner Wi
09-11-2002 11:13:08
I have never seen or heard of a reground camshaft needing different size bearings. That is a whole different problem. Would not hurt to check the fit of the camshaft in the block. You don't want the bearings too loose to bleed of what oil pressure you do have going to the rocker arms.
