...also, how hard to change rear pto shaft?
George
09-13-2002 18:57:11
The pto shaft on my TO 20 has been damaged. How hard is it to replace this?
George
rod
09-13-2002 19:25:46
 Re: ...also, how hard to change rear pto shaft? in reply to George , 09-13-2002 18:57:11
how damaged if it is twisted internally it is a chore if just the end is messed up you just pull front end into a low ditch and loosen four bolts at shaft end and pull it out. I took one in and had a new bearing put on at dealer and then put it back in. If it won't pull out you have it twisted up inside and that is another story.
regards
rod
George
09-13-2002 19:37:01
 Re: Re: ...also, how hard to change rear pto shaft? in reply to rod, 09-13-2002 19:25:46
Thanks, I believe it is only outside damage. It turns smoothly but the splines at the end are messed up.
George
Jim W
09-19-2002 18:47:29
 Re: Re: Re: ...also, how hard to change rear pto shaft? in reply to George, 09-13-2002 19:37:01
While you're at it you could switch to a shaft with 1 3/8" splines, if you want. I think I read somewhere that the ones they have available for the early Fords will fit.
JIm W
