Cold valve adjustment
steve
09-17-2002 17:02:08
Can anyone tell me how to do a cold valve adjustment on a TO 30.The cold setting is .015,but i don't know what order to adjust the cylinders in? can someone help me.
Fred OH
09-19-2002 12:21:03
 Re: cold valve adjustment in reply to steve, 09-17-2002 17:02:08
If the firing order of the engine is 1-3-4-2...then get the valve on number 1 and adjust it...then 3, then 4 and then 2. I just rough them in and then when engine is started and idling slowly,I check them closer. There should be slight pull when the feeler guage is inserted between valve stem and rocker. L8R....Fred OH
steve
09-19-2002 13:25:48
 Re: Re: cold valve adjustment in reply to Fred OH, 09-19-2002 12:21:03
Thanks for all the help.
Larry in Missouri
09-18-2002 09:29:58
Since this is a 4-cylinder engine, you can use the "rule of 9". As you rotate the engine, take the valve number of a valve that is fully open (down all the way, numbered 1-8 from front to back), subtract it from 9, then adjust the valve that is the result. In other words, if valve 3 is down all the way, subtract 3 from 9, which is 6, and adjust the clearance on valve 6.
Works for me...
Larry in Missouri
