6 volt battery charger hook up
steve
09-19-2002 13:23:31
Does anyone know how to hook up a battery charger to a 6 volt battery? Does the pos(red)charger cable hook up to the neg battery post & the neg (black)charger cable hook up to the pos battery post?
Jeff
09-20-2002 06:06:22
 Re: 6 volt battery charger hook up in reply to steve, 09-19-2002 13:23:31
Ditto what phil said.
Black is always Negative. Make sure you have a 6 volt capable charger.
Phil (VA)
09-19-2002 13:37:52
Red to pos and black to neg, as you would normally hook up. Some battery chargers don't have 6 volt options. The ones that do have a switch or some means to determine that it is for 6 volt versus 12 volt. Make sure you have it set for 6 volt. If it has no option it probably only works on 12 volt.
