Ferguson loader
Badger
09-22-2002 13:43:56
Does anyone know where i can get a manual for a ferguson L-UO-20 loader i got a loader but need a book to figgure out how it fits on the tractor any help will be appreciated
thanks
Barry Reid, stirling Ontario
09-24-2002 04:54:29
 Re: ferguson loader in reply to Badger, 09-22-2002 13:43:56
Good Morning Badger. I happen to be the owner of one of those Ferguson Loaders, But I dont have a manual for it, but I can tell you how its mounted onto the tractor. At the front of the tractor is the assembly where the tires are mounted, on each side of the hood , down low are a series of bolts. mine has 3 on each side. They look like they are holding on the front axles, which they are, but they are also to mount your loader. My TEA-20 came with the loader already mounted. On each side of the hood you will need to take off 2 of these bolts and mount your loader, you may have to get longer bolts as you will be keeping the wheels onto the front axle as well. If your loader is the same as mine, you will also see 2 long bars at the ends of the hydraulic cylinders, these mount under the tractor rear wheels and also hook onto the 3-point hitch in the lower postion. But the unfortunate thing is when you mount this loader your 3-point hitch becomes useless. So much so that I took mine off and its now in a corner of the fence to be used at a later date or sold. I hope I have helped you Badger
badgerwy
09-28-2002 20:05:39
 Re: Re: ferguson loader in reply to Barry Reid, stirling Ontario, 09-24-2002 04:54:29
Barry thanks yes you have helped...my tractor already has the brackets on the front end one on each side as far as not being able to use the 3 point is no big deal i have 3 fergies and am looking for no.4
thanks again badger
