Tappet order
Andrew
09-26-2002 01:35:19
Hi!
Is there an order in which the tappets on a TEA should be adjusted? If so, what is it?
Thanks!
dennis in Ma
09-26-2002 06:45:32
 Re: Tappet order in reply to Andrew, 09-26-2002 01:35:19
nope, just be sure that the cylinder you're working on is at TDC on the compression stroke and do both the valves on that cylinder. Turn over the engine to whichever cylinder will be at TDC next and do it. Repeat with the others.
dennis in Ma
09-26-2002 06:45:32
