Broken spark plug
tom
09-26-2002 14:05:51
i have a ted20 with a broken spark plug any ideas on the best way to remove the said item thanks in advance for any help
John, IN
09-26-2002 17:57:30
 Re: broken spark plug in reply to tom, 09-26-2002 14:05:51
Try putting a little heat on it and at the same time you are using the easy out try tapping it with a hammer lighty while turning it.
John, IN
09-26-2002 18:54:11
 Re: Re: broken spark plug in reply to John, IN, 09-26-2002 17:57:30
For got to say watch that gas if you use a torch. A heat gun is a safer to use. (not as hot) Good luck.
Fred J.
09-26-2002 14:24:48
can you describe a little what part of the plug is broke.
tom
09-26-2002 14:33:37
 Re: Re: broken spark plug in reply to Fred J., 09-26-2002 14:24:48
the bottom of the plug in broke in the head i tried a small stud extractor but the remaining plug is seized in there. so i gave up on that idea as i dont want to break the extractor in there incase i have to drill the remaining plug out
