Smoking Starter on my TEA-20
Barry Reid Stir
09-27-2002 04:30:02
I guess one problem leads to another. I took my carb apart last night and cleaned it and put it back on from advise I got from this site. There was a ton of crap in there. I decided to try and start the tractor and it rolled over a few times then nothing. I thought that maybe I run the battery down so I boosted it with the truck. Apparently the battery was fine, because all of a sudden smoke started to roll out of the starter. Have a burnt it up? (the starter that is) Are replacement starters available? Again I must convey to you guys, Im still learning about this tractor, costly as it may sound. But I am having a blast with it, even tho its costing me a few $$$$$$$$$
Jim W
09-30-2002 09:15:40
 Re: Smoking Starter on my TEA-20 in reply to Barry Reid Stirling, Ontario, 09-27-2002 04:30:02
OK so what colour is it? I have a non-grey unit and have been trying to figure out why to no avail.
Jim W.
Joe in NY
09-27-2002 19:15:51
Barry, If you did smoke the starter it's not because you put 12 volts on a 6 volt starter. When you convert to 12v from 6v you don't have to change the starter. A starter is a high current high torque motor. The windings are not heavy enough to leave in the circuit for long periods of time or many repeated starts in short time. Put your hand on the starter after repeated attempts to start and you'll feel what I mean.
I assume you hooked the jump battery to your battery and attemted to start with the shifter correct? Did you continue to crank for an extended time?
Does the starter try to turn with the jump after it cooled down? Smoke doesn't mean it's shot, you just put a few years on it! You can pull it easy enough and your nose will tell you if it's burnt..believe me.
Hope it helps.
Good luck,
Joe in NY
glen/ Ontario
09-27-2002 14:21:37
Barry You have a lucs starter here is a tel number this guy is in montreal he has tons of patrs for this motor he might have what need off the sfelf call 514-639-4639 his name is Chris Holms good luck
DouroBob
09-27-2002 08:18:55
Hi Barry
You just never know when to stop having a good time do you?? {grin}
Bob
Steve Barr
09-30-2002 08:13:43
 Re: Re: Smoking Starter on my TEA-20 in reply to DouroBob, 09-27-2002 08:18:55
You sure create quite a fuss on the web page. When I was down looking at you funny colored 2085 I told you I had the name of a parts supply outfit out of western Ontario. They actually have a small catologue of TEA 2085 parts. Call them and they will mail it out.
Lynnville Farm Equipment
808 Regional Rd. #4
R.R. #1
LaSalette Ont.
N0E 1H0
519-443-7591
The list of parts it pretty good and the prices seem fair.
see ya soon.
Steve
Barry Reid, Stirling
09-30-2002 10:17:33
 Re: Re: Re: Smoking Starter on my TEA-20 in reply to Steve Barr, 09-30-2002 08:13:43
Steve
Ouch, A FUNNY COLOUR ????? ????? ????? ?? THE CAN OF PAINT SAID FERGUSON GREY, How was I to know that metalic grey was not an original colour. But it sure does look better than it was. Dont worry the next time you see it It will be the RIGHT colour. Thanks for the info. I will call them. See ya soon. Hopefully under better circumstance, But none the less great to see you and Marney, Stay well, Barry
Gary F
09-27-2002 06:11:50
Barry, what year is your 20-85? Early models used a 6 volt pos-ground electrical system. It may be possible that the starter was replaced with an earlier 6 volt starter and used with a 12 volt system. Most rebuilders would have no trouble re-manufacturing the starter for you. When you get it back it will give many years of service.
Gary
09-27-2002 11:07:43
 Re: Re: Smoking Starter on my TEA-20 in reply to Gary F, 09-27-2002 06:11:50
Gary My TEA-20 is a 1952, and the starter looks original. But saying that I cant be sure
Gary F
09-27-2002 21:09:18
 Re: Re: Re: Smoking Starter on my TEA-20 in reply to Barry Reid Stirling, Ontario, 09-27-2002 11:07:43
Barry, Your "52" should be a 20-85 and it would have a 12volt pos ground system.
gary
Jim W
09-27-2002 14:30:22
One of the differentiators between a 6v and a 12v 20-85 is the size of the starter hole in the block. If you know it's a 52 then that would make it a 12v, so a 6 v starter from a TEA wouldn't fit. Who knows, a 6v starter from something else might...
If you have a UAP nearby give them a call and they'll probably recommend somewhere nearby.
Jim W
Jim W
09-27-2002 04:42:55
Yup, take it to a local alternator/generator/starter shop; they will be able to deal with it. I had mine done not too long ago; it needed a field coil and they told me that even if there weren't any around they could get one made for it for about $40. Mine even had a bent shaft and they straightened it.
More fun and more $.
JIm W
