Bearing question
glen
09-28-2002 08:49:17
Is it normal when instaling new bearings main or conecting rods that the new bearings are too long and when touque is applied it will bunch at the end do I have to trim these or is this bearing non spec and should be returned ?
dennis in MA
09-28-2002 12:53:22
 Re: bearing question in reply to glen, 09-28-2002 08:49:17
They should fit with no overhang. If you've got overhang, you've probably got the wrong bearing OR someone filed the caps and used shims which means you need new caps. Shimming is very difficult to do especially if a lot is required. You must not squash the ends of the bearing inserts.
