Ferguson Plough ID?
SAm in NS
10-01-2002 12:45:49
I am trying to Id a Ferguson moldboard plough. It is 3pt. compatible, has a single moldboard, and was made in Dearborne, Michigan. The data plate states it is a "Type 12-AO-28" and it is "No. 48765". Any info would be great. Thanks in advance. SAm in NS
Phil (VA)
10-02-2002 08:14:12
 Re: Ferguson Plough ID? in reply to SAm in NS, 10-01-2002 12:45:49
The numbers stamped on the back of the moldboards and shares will be helpful if you need parts. Some parts are available, some may not be available.
Scott
10-01-2002 17:58:09
The tag says it is a 2 bottom (moldboard) 12" Ford Ferguson plow made from 1943 to 1945 but 1 beam may have been changed or turned to make it a 1 bottom or the ID plate was swaped.
